Slowly the CV noise had crept in and now it was time. I elected to replace the axle for $59.00 as many of you have also done. Passanger side, so I removed the wheel to get it out of the way.
Now the unusual takes place, I could not snap out the axle from the tranny. I snapped and pulled, this would not budge. I began to think it had a lock ring on it instead of the snap ring. But upon checking here on the fourm again. I determined it just must need more encourgment. So I rigged up a RG to do the job.
A trailer hitch (for mass), and 16" of chain to provide the shock like a slide hammer, and a short piece of rigid pipe to fit over the axle. While trying to remove it from the tranny I snapped out the CV spline nearest the wheel. So I rigged the pipe on to the axle near the ridge where the boot sets.
It took 4 or 5 Progressively stronger snaps on the chain to finaly pop it out.
I must confess I was wondering if it was going to work or not. A real tough removal but it did snap out. This message is for any one who is having problems removing the axle easil. IT DOES SNAP OUT AS PROMISED just maybe a tough one like the one I just finished.
