I think that's what it's called. In the distributor. Senses crank/distributor position.
If it is faulty, what running abnormalities will I see in the engine. Spark knock? I'm getting an occasional hard spark knock for no apparent reason under slight load. Then, just as quickly, the spark knock goes away. It will even do it using premium gas but not as bad. I haven't checked initial timing yet only because I don't think that's the problem. The problem is intermittent. How would I check it for function?
The fuel mileage is around low/mid 30's which to me is unacceptable even if it is an automatic. That's featherfooting the gas pedal, mixed urban and highway.
Other than that, runs good.
