Quick question as I am a novice mechanic. I've done a complete tune up with the exception of the fuel filter (93GL, EFI) and now want to change that. I need to release the system pressure but do not have a gauge nor can I find the fuel cutoff. Any suggestions on how to relieve the pressure before I remove the filter?
Fuel Filter Change
Got the fuel filter changed but now the car won't start. Won't even turn over. I checked the battery and it's fine. All I did was change the filter. What could I have missed? The owner before me put the wrong filter on so I had to put the correct one on but doubt that has anything to do with it. Please help!!!'93 Festiva GL / "HOT ROD"
'02 F-150 Supercrew
'02 Excursion 4x4
'98 Jeep Cherokee Classic Limited
There is a small wire that goes on the starter. Maybe you bumped the wire off.
I get lights but no click, turn over or anything. I thought maybe I tripped the fuel shutoff but it would still try to turn over. I will check the starter wire.'93 Festiva GL / "HOT ROD"
'02 F-150 Supercrew
'02 Excursion 4x4
^^glad to hear you got it running again!!
