Buyer beware!! I bought my Festy knowing it had some work to be done. Expected about $200 to $300 worth of parts and now I'm at about $400. Before I bought the car I checked it out from top to bottom, inside and out. No major warning signs AT ALL. After one week at home I blew a head gasket and found the radiator full of oil. Had a friend of mine that's a very good mechanic do the work on the head which included new gaskets, grind valves, etc. etc. Did compression tests and left nothing to chance. Car ran a little rough but after I did a complete tune up (plugs, wires, dist cap, rotor, fuel filter, timing belt, hoses, air filter, pcv valve and more) she runs so smooth it's unreal. Last night I noticed a pretty significant oil leak that appears to be coming from the valve cover which has a new gasket. Apparently it didn't set well. Then today I checked the coolant and guess what I found? Black gold!!! My radiator is again full of oil. It's as though everything was ready to break and I bought it at just the right time....for the previous owner. When I'm finished everything will be new but I'll be broke. Please tell me there is a positive end in sight.
