Carbed troubles
  • Carbed troubles
    I am helping Spiko with his car. It is a 88 carbed with a manaul trans. The problem is when you try to drive it and place it under a load the car wants to buck on take off and has no power when driving. You can push the pedal down and nothing. It just goes flat, no power no reving it does nothing. Tried plating with the timing, even tried another dist. When sitting still in the driveway it will free rev without any trouble. I am thinking it might be the carb, but the carb came off another engine that it supposedly ran OK on. Any thoughts?
    93 GL modyfied!!!
    :fish:
    When mine was having all of it's ultimately terminal carb problems, when I changed the cat that problem went away. Never was able to resolve idle/timing issue. But the problem you are describing went away on mine with a new cat converter. Don't know how old the one is that's on the car now.
    1988 L - 232K miles Batstiva
    1989 L - 247K miles Slick
      Whole new exhaust including the cat.
      93 GL modyfied!!!
      :fish:
        I hope it is not the same problem my son has on his Omni.....runs fine sitting there...revs no problem....but if you try to drive it.... it dies ,bucks...no power like you are just flooding it out. Turns out it has a dead cylinder. Did a comp check and it was less then half the compression as the other 3. But while it sat there you would never know there was a problem
          Hmmm....... somethng to check.
          93 GL modyfied!!!
          :fish:
            fuel filter not allowing enough fuel to go through under load?
            #2 .....Cheesehead
            #3 '91 White - Donor Car
            #4 .....Montana Project
            SOLD----Levistiva for $1500
            Bought her back for $450
              Replaced it already. The engine ran good before we pulled it from the doner car.
              93 GL modyfied!!!
              :fish:
                Anyone have a diagram for all the solenoids on the firewall for the carb?
                93 GL modyfied!!!
                :fish:
                  mines a carbed 4spd. throttle only matters from none to half. when you floor it, nothing happens. and it always buck in 2nd. i just learned to deal with it. its WAY more dependable than my truck.
                  it'll do the 1/8 in 13.7, spin tires, and make all my drunk buddies giggle.
                  "I like a Festiva because there's less car to get in the way of the driving experience"
                    Not a carbed festy guy... idles and rev's while parked but no snot while driving.....
                    Poor fuel delivery.
                    or
                    Obstructed air inlet
                    or
                    Ignition advance is not working
                    Joe Lutz
                    The SKATE ..... 1992L 5spd
                      I'm thinking its in the fuel delivery, I have changed dist. And tried it without an air filter.
                      93 GL modyfied!!!
                      :fish:
                        I have to agree. Check the tank sump and the fuel pump output. Watch the float sightglass while accelerating.
                        Jim DeAngelis
                        kittens give Morbo gas!!
                          O2 sensor? my old 88 did this and we fixed it with the o2 sensor.
                            O2 sensor would most likely give a 'check engine' light, I'm thinking vacuum leak or vacuum hose connected wrong. I've got a FSM, but no scanner.
                            '92 Geo Metro XFi
                            '87 Suzuki Samurai
                            '85 F150, modded 300cid
                              apparently im gonna dump a bunch of seafoam in mine
