why no heat?
    A Festy will not put heat out of the vents. They are not capable of doing so. Heat only comes from the defrost and floor. If you have no heat from the defrost...check the floor too....if no heat hopefully it is only the thermostat and not a plugged heater core.
      It's easy to check a thermostat by the way - pan of water on stove, meat thermometer, t-stat on wire so you can dunk it.
