Well.....I am severely frustrated with my car. Maybe someone else has a idea.
'90 Festiva L Plus. I just swapped the motor. The car has about 192k on it but the motor I put in only has 69k. I am pretty sure the new motor came out of a automatic because the transmission braces were much larger and in a different location. So....
I have spark on all four cylinders
I have it timed correctly
I have fuel pressure.... or at least I do up until the regulator
I have good compression 180psi all the way across the motor
But it won't start! Let me correct that, it will start....
If I take a gas soaked rag and put it on the throttle body it will start. Or if I put some gas into the intake piping it will start and run till it uses up that little bit of fuel. But it will not start or run on it's own fuel system.
So I am clueless, any ideas?
