I bought a 1993 festiva that had been raced(my first festy) and had hail damage. The odometer said 113,xxx miles. The engine seems to be really noisy on the top end, but it runs fine. I have replaced the passenger front axle, all front rotors and brakes, front wheel bearings, oxygen sensor, exhaust, tires, driver's side ball joint, etc...
I bought this thing for $1000, I now have $2300 in it. The steering rack is shot. The gas gauge only works from full to 3/4 full. Sometimes the speedometer jumps all over the place, especially when cold but the odometer is still working correctly. I am getting 41mpg on 87 octane, and I thought I would get better. When I am going about 65 mph or above, the front end shakes really bad. I put new tires on and didn't fix the problem. I moved the tire configuration around and the problem stays. It may be a bent wheel, or the steering rack. Where the inner tie rod connects to the rack, you can move the tie rods up and down quite a bit.
For me to keep this thing, I need to come up with at least a speedometer head, a new steering rack, and preferably a drivers side front axle. Buying this stuff from Autozone or wherever is killing me.
Am I just stupid to keep dumping money in this thing, or do you folks know of a good source for quality used parts. By the way, I have saved about $800 in fuel over driving my truck. I drive 110 miles a day.
2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
