Originally posted by jglutz
I suspected the head had been off this car.
My car has almost exactly the same symptoms , and the dist. is ALL the way to one side of the adjuster (dist. turned CW) . So what you are saying is that I need to turn the cam one tooth CCW to get the distributor lined up properly ?
How will this affect performance other than ignition timing ? If my cam is one tooth off, then the valves are improperly timed with the pistons, right ?
No wonder this thing runs so erratic.
How do I check the IAC ?
I'll look for vacuum leaks , too.
.....................Blake
I'm learning though and having fun.
