Is it normal for an Aspire to run out of gas while still showing 1/4 tank?
This morning I started having the tell tale signs of running low on fuel. Very slight miss, loss of power, etc. When I made the turn off the interstate it spitted and sputtered a couple of times. (This is the second time this has happened with the spitting and sputtering when I’m at ¼ tank of gas and making a turn).
I put in exactly 7.55 gallons of gas with it filled to the top of the neck… (I wasn’t watching it and actually over filled it…)
So is this “normal” and will I have to fill up before it even hits the ¼ tank mark?!?!?! I should easily have another 50 miles in it… :cry:
Where I filled up, gas was $2.53. Where I usually fill up, 10 miles down the road, it was $2.41…. Grrrrrr. Needless to say, I wasn’t happy!! :x
