Originally posted by gareth69
Valve noise, lots of it.
Generally you would get the noise at idle speeds when there is acceleration and decelaration of the crank, would go away when accelerating. More of a chatter than marbles in a can. If you have that sort of noise I would think that something is loose and rattling. Possibly cat converter/ muffler internals.
Originally posted by KrayZFrameRate View PostGot the motor from Dean with my car. I am not sure on the year of the motor, 90 and up I would assume as it is EFI.Jim DeAngelis
kittens give Morbo gas!!
Originally posted by Mike McKown View Post"marbles in a can" was referring to the random cadence of the chattering, clattering or rattling noise. Does this mean the pump is worn? Emminent failure? What causes it?
It's not a baffle in the exhaust. It's in the engine. Not the valves.
0w30, 5w30, 10w30.......it's basically all the same this time of year It's very important in MN winter though.
The number before the W doesn't come into play on OHC motors until about freezing. Until that point all of them flow pretty close to the same. Most 0w and 5w will flow a bit better at room temps, but it's not a big difference when it comes to how the motor works (oil pumps are positive displacement, so every turn of the engine moves the same amount of oil.....so the only way to move more oil is for the engine to turn faster).
But the holes on those HLA are pretty tiny. So a thinner oil does go through them better, but they also clog up very easily since they're so small.www.dantheoilman.com
Go ahead and ask me why
I wouldn't advise it.
That stuff is WAY WAY WAY too thick.
Chances are, it managed to get into the HLAs and now is just too thick and gummy to leak out of them.www.dantheoilman.com
Wow....that often....I wouldn't waste the money....I just overtighten my valve cover gasket so I have to add oil every once in a while....then no change is needed at all!"FLTG4LIFE" @FINALLEVEL , "PBH"
hrm. i got less noise running 20w50 synthetic in mine, responds better too, for winter i ran 15w50. this has also given me a mile or two improvement in economy. does not like to stay in the motor tho, running the thicker oil motor tends to leak abit. last festiva i had i drove it for almost two years with this combination, 240000+ miles on it and it did not smoke or burn. no valve clatter or other noise from the bottom end and i drove it over a 5000 foot pass in my combined 700ish miles a week commute at the time. i would lose maybe a sixteenth to an eighth on the stick to leaks on the bottom end over the 4 to 5k miles i went between changes, and this was mostly dependent on temperature; did not leak during winter.is not sposed ta do that...
05 subaru legacy gt
1991 nissan nx2000(almost awesome as a festiva, my first failed mtx)
1988(?) festiva LX 5spd (rescued from crusher,aspire swap done, working on turbocharging the 1.3...)
is there a specific torque for the VC bolts? maybe THATS why my VC's always seem to leak... :lol:
not trying to thread jack, just curious.89 L, hopefully returning from the dead soon with a little more power... :twisted:
