1988 B3 Compression Specs?
  • 1988 B3 Compression Specs?
    Anyone that can give me the 1988 B3 Compression Specs? I.E. compression ratio, standard PSI and lowest PSI. Thanks for the help.
    It's more important that the cylinders pressures are close to eachother.
    www.dantheoilman.com
    Go ahead and ask me why
      what Dan said ^^^
      ratio is not important when checking performance, but its about 9:1
      and usually good cylinders will indicate roughly 125-200psi with throttle blocked open, cranked for 5 compression strokes each cylinder, all spark plugs removed, warm engine. Make sure fuel delivery is disabled as well.
      They should be within 10% of each other (about 15psi)
      Jim DeAngelis
      kittens give Morbo gas!!
        Is there any way to test the compression if I can get it running to warm it up first?
          you can check it cold, but your numbers will be slightly lower.
          Jim DeAngelis
            And if you have a low cylinder put a little bit of oil in the cylinders and if it gets better it is more likely a ring seal problem and if it don't it is either really bad rings or more likely valve/seat deterioration.
            Clinton
