Are 145/12 tires ok to run on my Festiva
  • Are 145/12 tires ok to run on my Festiva
    or should they be 155 or 165
    145R12 were original equipment on all Festiva L's with 4" wide rims. The 165/70/12 came on the LX, GL and L Plus with 4.5" rims. No problem using 145R12 on a 4.5" rim. The 165 gives a slightly better ride.
    Jim DeAngelis
      OK, Thank You
        The Master has spoken. lol.
        Seriously, can you actually find 145s? No one around here even deals with them now. 155s are everywhere, but no 145s.
        1988 L - 232K miles Batstiva
        1989 L - 247K miles Slick
          Yes, Tire Rack must just recently received a new order of the yokohama P145-80-R12's because they currently have them in stock.
          Two years ago, I waited 3 months for them to get them in before I finally ordered P155's.
            a few of the other online tire have the 145s now too.
            Jim DeAngelis
              How about going from 165/70/12s to 155/12s? I know the speedo will be slower and probably handling a little less but with a better than 3% increase in diameter will this create any braking problems?
              '93 Festiva GL / "HOT ROD"
              '02 F-150 Supercrew
              '02 Excursion 4x4
              '98 Jeep Cherokee Classic Limited
                ^ no, braking won't be an issue...i am running 165/70/13's... see the sticky in the custom wheel and brake.. with slightly bigger tire, you're speedo will be a little slow, but mpg's go up.
                -Aspire brake swap COMPLETE!
