Over Thanksgiving I plan to go on an 800 mile trip in my Festy. Driving will range from desert to forest to mountains.
I don't want a breakdown on my trip so I need to know if there is anything specific to watch out for.
Brakes: They don't make any noise, but I was told that the pads and shoes will need replacing within 5,000 miles.
Bearings: Front bearings are new with 10k on them, back ones are probably original but they don't make any noise. Anything I need to watch out for?
Cooling system: The thermostat, brass radiator, and hoses are original with 135k on them, but there are no leaks and the hoses aren't rotten or bulging. The water pump and bypass hose were recently replaced.
Transmission: Was serviced a year ago at the dealer and shifts smoothly. No leaks or weird noises/slipping.
Engine: Has an oil leak somewhere, but that seems to be normal for B3s. I just changed the oil, and it makes no strange noises. I assume the timing belt was changed with the water pump but I am going to check. Has a new accessory drivebelt.
Electrical: I cleaned the grounds and terminals recently. Everything works fine, except for the radiator fan circuit. The alternator is charging and not making strange noises. Starter works great. It was tuned up recently too. The battery is ancient looking but it starts the car fine.
The only problem I can find with the car is the radiator fan. For some reason it is stuck in the "on" position so I just unplugged it for the winter.
I am also wondering about the rear bearings; I don't know how to check those and I have no tools. I assume they are fine because I hear no noise and have had no problems.
I gave the car a thorough inspection and don't see any obvious problems. It doesn't have any odd quirks or noises either.
Am I good to go? Any failure prone parts on the Festiva that might leave me stranded?
Regards,
Tim
Regards,
Tim
