ive put the new axle in, but dont know where to replace the gear lubricant, also i got a new fuel filter and just wondering if theres anything i should know before i pull the old one out.
I believe you put it in the speedometer cable hole. As far as gear lubricant, I believe everybody has gone to using ATF or Dexron III auto tranny fluid.
One thing you need to know about that fuel filter is make sure, and I mean this, make sure you don't have a lit torch near it when you remove it. A cigarette or joint is okay, but not a torch!
Don't quote me on any of that, but I am about 99% sure.
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Are new axles supposed to come with new clips or any other pieces for reinstallation? Its been a long time since i took apart the aspire, and I muscled it apart because it was going to the junker anyway.
1993 GL 5 speed
I'd noticed somewhere recently a dissing of a person using atf in a tranny; which a better product was named as highly more regarded...(?) Even though as w/Festiva the atf is what is recommended...
'91 Festiva L/'73 Windsor Carrera Sport custom
(aka "Jazz Bobstad," "The BobWhan," etc.)
Art is the means whereby(a) society advances: Religion is the definition of the parameters of art. Poetry is the actualization of these...
It takes transmission fluid, not gear oil. Discussed millions of times, and... ITS IN THE BOOK.
Dont kill it with gear oil. I put Valvoline synthetic ATF+4 in mine (for chrysler autos) its a little more oily than dex/merc I think. No problems here.
I would use just about any trans fluid, except maybe Type F, which is thinner and may not be oily enough. Unless maybe if youre in a really cold climate.
91GL BP/F3A with boost
