The ATX in my Aspire, is it electronically controlled?
  • The ATX in my Aspire, is it electronically controlled?
    Judging by the way it downshifts, I'm thinking that it is. If I'm crusing along at 40-45 mph on flat ground and I stomp the pedal to the floor, no downshift. However, if I'm going up a steep hill at the same speed and stomp it, it usually will downshift. Is this normal?
    normal.
    fully mech/hydro shifted
    no electronics
    down shift is based on vacuum signal, not throttle position.
    Jim DeAngelis
      Ok, thanks for clearing that up. Lately I've actually been able to get it to downshift. I just have to floor the pedal, then press it a bit more and usually it'll downshift for me.
        adjustement
        adjust your switch under the gas pedal...or push harder on it
        the fastest aspire auto in the world
