Posted this on the aspire site but it gets traffic like...Kansas...
I found out what was killing my clutch cables. The tack welds failed on the bracket which let it rub back and forth. Anyway i went to a yard and got the whole bracket which was a pain to take off, as its bolted to the back of the master cylinder. Anyway the proper way to get it out of the car is to remove the steering column completely. I did this and now, am having the worst time reinstalling it into the car. i put it on half way to be able to move the car, but afraid if i leave it like that, i may hit a bump and lose steering of the car and crash. First i tried putting the u-joint on the column and sliding it onto the rack, and failed. Then i tried putting on the rack end and sliding the column on and cant do it that way either. It sucks because i did get it on 2 seperate times and just can't anymore. Is there anyone here with autobody shop experience or something that knows a trick to get this car back on the road? Just as this happened price of gasoline dropped like a rock so ive gotten lazy to fix it but i need this finished. I have the worst kind of BS luck with cars. Nothing that is "supposed" to screw up ever does...its the weird most annoying stuff that you just cant take to a mechanic for a quick fix.
