Ok, i am doing my 5spd swap..
For removing the auto transmission, do I need to lower the engine as well? I am thinking i have to b/c in order for the trans to separate from the engine, it must slide out 3-5 inches, and there isn't that much room unless you raise or lower the engine/ trans assembly. I am to the point of removing the trans bolts, and I'll start first thing in the AM.
