I believe that Jim stated before that the shim is for the hub....the bearings are made to exact specs and the hub is the issue so it needs the shim.
Front wheel bearing shims
Yes....from previous post....many of us have used the original factory shim without incident. The shim (spacer is to compensate for the machining of the knuckle. The bearing bores are done from differnt sides of a casting...not the most percise way. The intention of the sevice manual is that if the knuckle is changed...the shim length must be re-determinedOriginally posted by freshtiva View PostQuestion:
Will the shim size that came originally on the knuckle be the size you will aways need with that particular knuckle ?
Try MSCOriginally posted by Levitan View PostI just found the post. He said early Rio's.
The expensive part is going to be the torque wrench that does inch pounds instead of foot pounds.
http://www.mscdirect.com
http://www1.mscdirect.com/CGI/N2DRVS...00000077169168Joe Lutz
The SKATE ..... 1992L 5spd
Hey Brian,Originally posted by 25Horseplay View PostI have some shims laying around. Aong with the inch pound torque wrench there is a tool to preload the bearings for checking the drag with the torque wrench.
Any chance of a pic of the tool?ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Originally posted by jglutz View PostYes....from previous post....many of us have used the original factory shim without incident. The shim (spacer is to compensate for the machining of the knuckle. The bearing bores are done from differnt sides of a casting...not the most percise way. The intention of the sevice manual is that if the knuckle is changed...the shim length must be re-determined
Try MSC
Thanks Joe, thats what I was thinking. No need for other shims if you keep the original shims with the original knuckles. Another question. Are the shims sizes usually different from left to right side on the same car ?sigpic
I'll take one for you.Originally posted by Levitan View PostHey Brian,
Good Qustion....I don't know. When I did my front bearings I kept the knuckle and shim together.Originally posted by freshtiva View PostThanks Joe, thats what I was thinking. No need for other shims if you keep the original shims with the original knuckles. Another question. Are the shims sizes usually different from left to right side on the same car ?Joe Lutz
When I replaced my first set of front bearings, I used the same hub and spacer, but when I put it back together there was so much preload on the wheel I could barely turn it. I couldn't find spacers anywhere, so I just made my own shim. I don't remember how thick it was, but I'd guess 4 or 5 mils. Actually, I may have stacked two or three together, so it was probably more like 10 to 15 mils. It was a long time ago. Anyway, it worked fine with the added shim. My dad replaced a set of fronts a year or two ago, and didn't have any issues with preload.Last edited by gdawgs; 12-03-2008, 11:27 PM.
I've replaced the bearings on four different cars useing the shims that came out without any problems!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
Yes they are different from side to side. If you look close there is a number on the shim, I think they are numbered 1-21 if I remember correct. I'd have to go look at one to be sure.Originally posted by freshtiva View PostAre the shims sizes usually different from left to right side on the same car ?
