1988 Engine Swap
  • 1988 Engine Swap
    I have a 88 Festiva that got hit and is done. I found a 92 that needs a engine. Can I swap the 88 engine into the 92? 88 is a 4 speed and 92 is a 5 speed.
    Thanks for any advice you can give. Don
    The '88 is carbed, you knew that!
    The '92 is EFI.
    You will need to swap over the intake and exhaust manifolds from the '92 to the '88 engine and block off the fuel pump port on the '88.
    Might be some other odds and end to swap over from the '92 to the '88.
    The alternator comes to mind.
    Do either of them have AC?
    But you should have all the parts to do the swap!
    Where are you located?
    Might want to consider putting that info in your profile.
    This way, near by members might be able to give you a hand.
      I have a friend named "Dan" Morrison!
      Steve GT
        Thanks!!
        I will update my profile. Just got signed on today so I'll be up to speed soon. I live in Spokane WA.
          Not a problem!
          Spokane, WA, think we have a few members out that way!
          Anyone near Don want to speakup!
            The WA area is teeming with festivas. What's going on with that?
            1993 GL 5 speed
              Go in the snow!!
              I picked up my 88 in April of 2007. In the winter of 07-08 we had record amounts of snow. My little Festiva went anywhere I pointed it, right past the the big old four bi's.
                You will need to swap the distributors also.
                1960 willys pickup
                1967 jeep cj5
                1988 festiva
                1989 festiva
                1990 festiva for parts
                1991 s-10
                "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
                  And then sell the carbed distributor because they are wanted at times. ANd I think somebody in Ohio is looking for a good carb. Just passing along some financial gains to you.
                  #2 .....Cheesehead
                  #3 '91 White - Donor Car
                  #4 .....Montana Project
                  SOLD----Levistiva for $1500
                  Bought her back for $450
                    I had one for sale if anyone needs one, for a carbed model.
