I had my mechanic of 12 yrs put in my rear bearings for me.I bought them and he installed them.Anywya,no torque.He just put them in (everything new including races).He put it all on ,tightened it all to "seat" the bearing and backed it off and re tightened it ,put nut cober on over and cotter pin it.What should I expect.? He has always worked on my cars and says torque in this case was not needed .He has never failed me in the past,but......
rear wheel bearing question..
that's the correct procedure.
front bearings are torqued.
rear bearings are seated and tightened. if you do them up too tight you'll wreck the bearings.
what his post said.Originally posted by SoCalZ28 View PostBut what?
if you're not aware that the rear wheel bearings don't have to be torqued, i can see how he would feel uneasy about driving the car when you're used to seeing almost every other part torqued up to spec.
Hey smc,
The procedure he used is somewhat correct. Some ppl have the "touch" for doing it that way. I think elcamino1 has the "gift". I do or did on older Chevys and whatnot, but not on Festys. I had miserable failure coming back from Ohiostiva. Ended up having to replace the spindle and everything. I used a torque wrench and my own little procedure using the specs from the manual and have gotten great results.
If you know how to check for bearing looseness, jack the car up every 200 miles and wiggle the tire. You'll know if they are coming loose, within 600 miles (the distance from Iowa to Ohiostiva and back..lol). Then take a torque wrench, while spinnining the wheel, tighten to 16 ft lbs, then 18 ft lbs, then 20 ft lbs, then 21 ft lbs, then back then nut off 1/4 of a turn, then tighten 3-7 ft lbs. Your torque wrench will not even go that low so it is just a smidge, or as I like to say, most people can fart more torque than 3-7 ft lbs...LOL!
Anyways, I'm not telling you what to do, I am just saying that is what I would do if I were concernedENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
That comment scars me....races are always changed....If he had left you with the idea that cages can be changed without changing the races....I would have grave concern.Originally posted by smcawc View Post(everything new including races)
There are many mechanics that do have the skill to tighten bearings without a torque wrench.
To all....remember this...many states that have annual safety inspection that requires one front wheel and one rear wheel be removed for inspection of the linings and harrdware.....this being said....think about how many inspections are done...with out the service manual and without incident.Joe Lutz
The SKATE ..... 1992L 5spd
You can drill a hole for a cotter pin in the rear spindle with a sharp bit, a good drill, a steady hand and some patience. Or use a drill press if the spindle is off the car. To match the spindles that have holes already, my machinist buddy at work measured it then had me use a 0.116" bit centered 0.241" behind (toward the center of the car) the outside face of the spindle. I had no problem drilling the holes.
I agree with other folks' advice, which is make sure the "crush nut" isn't split when you beat it into the groove of the spindle. It needs to be deformed down into the groove enough to keep the nut from working loose. Shop manual sez use a "cape chisel" (which has 2 different angles on the tip) to stake the nut in the groove. We dulled the edge of a regular chisel a tad with a hammer so it wouldn't cut the metal in the nut.
Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
In memory of Dean Allen - V8 Festiva 1955-2010
right.Originally posted by Mike McKown View PostI have never seen an application where tapered roller bearings were set to a pre-load or zero end play. There has to be clearance or you'll burn them up.
at least he didnt tighten then clockwise! if he hasnt failed you yet, why doubt him now?
