As some of you know, I am doing the auto to 5 spd swap. Ok, got my flywheel on and new clutch. Haynes calles out 13-20 ft lb for the pressure plate to flywheel... When i do that, and put the tranny in, my clutch release lever only moves like .75 inches, and that is all from the spring, not the throwout bearing against the clutch fingers.....hmmm..??
Heres how my day went: I think initially I over torque the pressure plate bolts to the flywheel.....put the tranny back on, and almost had it done....
then i go to push in the clutch and it doesn't disengage....
so i undo everything and remove the tranny and adjust my bolts.... still the same thing!
I don't know what to do! Unless this is normal!
So i have a question for all you 4 and 5 speeders... how much should the clutch release lever (where the cable meets the tranmission) move to disengage the clutch? Mine as stated above is only like .75", but thats only the spring.....
any help would be appreciated!!! I gave up for the night!
