I haven't really had much experience with Festiva A/C, aside from various experiments I did with my first Festiva.
My current car has dealer installed A/C but it doesn't work, probably because there's no pressure in the system. The previous owner can't recall it ever working and took the drivebelt off when she replaced the timing belt.
I did a search, and there doesn't seem to be much info here on failure prone parts that I should be looking for.
Right now I plan to take the entire system apart, do a visual inspection, replace the o-rings, flush it out with acetone, and replace the refrigerant oil. I'll also be replacing any obviously damaged parts.
I'm hoping my leak is just a bad o-ring somewhere, but if it isn't what is the next place to start looking? Do condensers/hoses/lines have issues with leaks? Or do I just swap stuff out until I get lucky?
Regards,
Tim
Regards,
Tim
