DRL modual
  • DRL modual
    location of the DRL modual in the aspire's?.......would be a great help...
    you want to blend in?, drive a honda
    92l festy car, original owner.
    2008 xls mitsubishi outlander
    1987 nissan diesel truck
    or even the location of my festy.....
      Daytime Running Lights?
      Does not exist on either festiva(for sure) or aspire (ive got a 97 last year they made em and it doesnt have it).
        Canadian Festiva have them. If I remember correctly there's a relay down by the battery and the small box on the firewall with the grille on it, about in the middle, is part of the system too. You can see what I'm talking about in this photo
        ... its right behind the adjuster on the strut bar.
        Hope that helps...
        Ian
          Let me check my electrical trouble shooting manual!
          US didn't have DRL's only Canadians, but manual shows all North American options.
          I'll just edit this post if I find it!
          Got it!
          OK, if the 1993 Ford Festiva Electrical & Vacuum troubleshooting Manual is to be believed; the DRL control module is "under the I/P behind the PCM". The location of the PCM is "Mounted behind the dash, left of the steering column."
            wow, of all my festys ive never seen that!
            you crazy canadians get all the cool stuff
            turbo diesel engines, defog strips standard on most cars and now DRL's too?
              I gotter figured,.....the neighbor has a aspire that I work on as well,.....he installed some fog lamps himself and zip-tied the wire to the drl modual on the fire wall...hence shorting out the whole system and burnig up the unit. I have a aspire in the back yard we stole a whack of new parts from,.....going to be -40 with the wind chill tonight, glad to be in the shop, playing with the toy's!
              Turbo diesel!!!,....That I have never seen or heard of!!!........Does such a demond exsist??
                X 2 billion!!!!
                Mike, AKA the sasquatch
                  My Canadian Festiva also came with a block heater.
                    P.S. My Canadian '89 does not have the DRL as daytime running lights did not become manditory under the law here until some later year - that would be provincial law.
                      In Canada they became mandatory in 1990
                      89SX funtop! Fully loaded!
                      RIP 90LX
