(FestYboy): this is why you should replace your brake fluid every 3 years or sooner...
brake leak
thanks guys.. i'll look for a new MC now... and inspect the other one thats in there now...
do you think that this was the MC all along (with the car pulling to the right) or something else?
-Aspire brake swap COMPLETE!
It might be your proportioning valve.sigpic
check your sliders on you left caliper and make sure the piston moves freelyTrees aren't kind to me...
exactly how do i do this? what i have done already is pinch the caliper piston with a C-clamp and removed my pads.... i don't know if that is what this "slider" is you speak of..?Originally posted by FestYboy View Postcheck your sliders on you left caliper and make sure the piston moves freely
Then i installed the pads and pins, and pushed the pedal and the piston moved up against the pad..
one more comment.. before when the car pulled right... the right caliper was hot and the left was cold or none... so the left isn't binding up or anything...
That usually means the right caliper piston is sticking and not retracting or the right front flex hose has deteriorated inside and is blocking return flow of the fluid.
i don't think anything is wrong with the booster...Originally posted by alpaccino View Posti'm having the same problem, i was planning to just change both my master cylinder and booster.
it looks like a faul in the model.
or the left caliper has a frozen piston, and will not apply.Originally posted by Mike McKown View PostThat usually means the right caliper piston is sticking and not retracting or the right front flex hose has deteriorated inside and is blocking return flow of the fluid.Jim DeAngelis
well, i replaced the MC and all 4 flex brake lines... problem fixed!
JAMAICA TO THE WORLD
