Rocker assembly swap?
  • Rocker assembly swap?
    Is the 88-89 full rocker arm shaft assembly a drop in fit in a 1993 head? Do the manual adjusters ride dead center on the valve stem? Or do they ride off center on the stem to rotate the valve when its lifted off its seat? Thanks
    Is that someone there ??? 1981 VW diesel pickup---1988.5 Suzuki Samurai tin top---1993 Festiva---1974 Bricklin SV-1 ( very thirsty basket case)---2003 Tracker(bells and whistles)
    yes, they're a drop-in.
    no, they're non-rotating.
    Jim DeAngelis
      OK thanks. I thought it was a direct swap but i wasn't 100% sure.
