I'm going to check out what seems to be a pretty good deal on a 89' Festy. It's a 4 speed I believe. The guy said it had a miss and he fiddled with the carb and now it won't take any gas. He said it'll start up and idle perfect, but when you give it a little gas it stalls. I think he just got something out of adjustment. What could this be besides the carb? Fuel filter, coil, plugs and wires? Also is there anything in specific I should look at or check (common problems, rusting spots) before buying. The guy wants $450 for it as is.
Buying my first Festy
First where are you? Second...because its a carb it doesnt mean its dumb. The carb/fuel delivery IS controlled by the ECU believe it or not...and there are tons of vacuum hoses. For $450 is a great deal if its not rusted and the interrior is good.
Just in case, I can sell ya the whole intake w/ carb n all for almost nothing....I just did a swap to BP so my whole engine is just sitting there.
Let me know buddyLast edited by lasvegascop; 12-21-2008, 11:22 PM.Ski
1986 Ferrari Testarossa
2002 BMW 745i
2002 BMW 325i
1989 BP'd Festi :p
I've never owned a carbed Festiva, but for the most part, the engines and transmissions are about as reliable as any car. They are easily capable of going several hundred thousand miles without any major repairs.
In the case of the car you are looking at, could he have missed a vacuum line? Probably something simple. If you do buy it, just do the normal routine stuff - spark plugs, wires, distributor, air and fuel filters, etc. and it will probably make a big difference.
I think about the biggest problems with Festivas are; 1) the parking brake quits working because the linkages lock up. 2) they go through mufflers pretty quickly. 3) "why don't I get any heat out of the front vents" (you won't, silly design). 4) We are starting to see stabilizer bushings go out due to age, easy fix though.
They don't really have any major issues if you take reasonable care of them. Very reliable cars. I've logged over 300,000 miles between the two that I've owned and have never had any major issues.
Anything major I'm missing guys?
I'm in central WV. I'm very familiar with carbs on early jeeps and trucks. but the computer controlled carbs never really struck me as a great idea. The guy really doesn't know a lot about cars and I figure he just started messing with stuff and got some lines or something on wrong. He said its just got one little patch of surface rust on the rear hatch.
Ok, I know you guys are gonna laugh a lot when I say this cause I see most of you all are trying to go faster instead of being more capable which is definately a good thing.....BUT I'm looking to get this thing (if I get it) as off-road capable as possible. I figure you could cut out the fenderwells for some bigger tires. Then maybe a B6 to turn those bigger tires. Any other ideas? I'm still thinking about wether to go with the "little indestructable kinda off-roadin' hell-raiser" or the "mini gas-miser go fast hatchback". Any and all opinions welcome here!
Please don't cut up and trash a clean festiva just to have some "Fun"Originally posted by wearethebucs View PostOk, I know you guys are gonna laugh a lot when I say this cause I see most of you all are trying to go faster instead of being more capable which is definately a good thing.....BUT I'm looking to get this thing (if I get it) as off-road capable as possible. I figure you could cut out the fenderwells for some bigger tires. Then maybe a B6 to turn those bigger tires. Any other ideas? I'm still thinking about wether to go with the "little indestructable kinda off-roadin' hell-raiser" or the "mini gas-miser go fast hatchback". Any and all opinions welcome here!-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
I guess I worded my previous post wrong. I just wanted to try to make it halfway capable off-road. Probably not anything more than gas well roads and such. On a different note would a 4x115mm wheel fit on this car? I know the Festies use 3x114.3mm, but 0.7mm difference might be able to go on with the right amount of persuasion.
If you are just looking to get down bad potholed/rutted/washed out roads you'd be suprised at how well they do stock. I've taken mine down its share of horrible logging roads/ doubletrack and its handled them great. They are small enough you can pick your way around most stuff and the short overhangs are handy if the road is really rough. And they are light enough that if you get stuck its pretty easy to get them out.Originally posted by wearethebucs View PostI guess I worded my previous post wrong. I just wanted to try to make it halfway capable off-road. Probably not anything more than gas well roads and such. On a different note would a 4x115mm wheel fit on this car? I know the Festies use 3x114.3mm, but 0.7mm difference might be able to go on with the right amount of persuasion.
Bigger tires or a inch or two of extra ride height would be nice but most of the time they are good to go.
Man a stock festy with 12's will climb 4 wheeler trails. They go awesome off road. I have awed many 4x4 folks with mine.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
