Okay I don't really know whats going on... I tried to bleed my brakes and my front right and back left won't bleed.. well really my pedal won't build up any pressure at all but the front right and back left just 1 drop comes out when I try to bleed them the front right and back left break fluid shoots out like there is no problem... so is it my break booster or some simple problem that I just seem to be overlooking..
brake's broke.... bleeding problem
Bleeder's maybe stopped up,pull them all the way out,then see if fluid flows out?Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
If you have rubber flex hoses going to the wheels that don't bleed, they could be deteriorated internally and block fluid flow. I haven't looked so I don't know how they're set up with the hoses.
Possibility also of the brake distribution block is the cause, depending how it routes fluid. I don't know how it's plumbed either but it's something to think about. You can crack llines coming off the block to check for flow there.
Your braking system is divided in two at the combo valve on the fire wall (the octopus-looking thing) so if one of a pair leaks the other pair will still work. Sounds like one of your pairs is out of order. Hope that info helps diagnose the problem.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
You need to pump that pedal fast and a little hard.
Pumping the brake pedal to soft or slow most times will not work.
For some reason these Festiva bleed jobs don't work like most old school brake bleed jobs.
Call me at 919-271-5190 if you like.
Dean
Raleigh, NCThe wife and I are attending this meet. Come convoy with us.Come to the 1st annual "Sunshine Meet" March 20th 2010. Details in the thread below.
http://www.fordfestiva.com/forums/sh...292#post295292
www.festivameets.com
Festiva Convoy video link [url]http://www.youtube.com/watch?v=VyFYJcFBc_g[/urlhttp://www.youtube.com/watch?v=ANbkG...eature=related
3rd Annual Festiva Madness. The largest Festiva Meet ever held of owners and their cars2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
FM3 short 5 minute clip
Link to a short 5 minute clip http://www.youtube.com/watch?v=VFyy-zxgV5A
http://www.fordfestiva.com/forums/sh...ad.php?t=24695
link to 100s of meets pictures and short video clips.http://s1019.photobucket.com/albums/af316/festivameets/
4th Annual Festiva Madness meet will be held Oct 2, 2010 in Raleigh, NC
Cell is 919-271-5190 deanraleighnc@cs.com
Originally posted by WmWatt View PostYour braking system is divided in two at the combo valve on the fire wall (the octopus-looking thing) so if one of a pair leaks the other pair will still work. Sounds like one of your pairs is out of order. Hope that info helps diagnose the problem.
If it's cross corner, it sounds like the piston in the valve is stuck and not letting fluid get to those wheels. As noted, sometime stomping or pumping hard on the brake pedal will center the valve piston. If the valve isn't centered though, he should have the brake warning light on.
I have the break warning light every once in a wile but they still don't bleed when i don't have it on..Last edited by gothguydante; 12-27-2008, 03:10 PM.
1989
Ford Festiva L
Automatic
