Upper Strut Bearings ???
  • Upper Strut Bearings ???
    I have disassembled my strut assemblies from the front springs, and there is no bearing in the top. There is a small flat washer between two hard rubber washers. Is this all there is? Or has someone in the past put it together wrong? This car is a '93 with an automatic trans. One reason for taking this apart is because this car steers much harder than my '91 with manual trans. I'm trying to figure out why. While it's apart I'm replacing the struts, CV shafts, front wheel bearings, and anything else I find. Any suggestions? Thanks for any help. Mark.
