Replaced the factory L cluster with a tach unit I got off ebay last year. When the car is off and sitting still, the speedo needle sits about 1/4" below "0"; to the point where it is actually down into the temp gauge area. Consequently, the speedo is about 5mph slow.
The same situation with the tach needle. My guess is the tach is also off about 500rpm since at idle it shows 850rpm but is too slow. My instincts tell me someone removed the needles, probably to adjust the milage and re-installed them incorrectly. Can the needles be removed easily and set back to "0"? any ideas?
