i backed my 90 festiva fuel injected in a spot in my yard shut it off and it has not started since no fuel and no spark checked the tilt switch and the button has not poped out turns over fine pulled the pump out and bench tested its fine new coil in it its fine i'm totally lost now
please HELP so lost i am
I would start with checking the main power fuses and fusible links.
Sounds like you lost a main power feed.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
The three fusible links on the drivers strut tower are what econo mentioned. Even if they look good they may be bad. Check the connections and everything there as well, its a fairly common problem. If you go to a parts store, get the cartrige fusible links (pink/green) with a clear top so you can tell when their burned through, they will plug right in to the festiva fusible links box.
Also, put your location in your profile and you might find that some nut that caries 20 or 30 or said fusible links around in their trunk lives close! (Yes, I have at least 20 in the back of my car
~Nate
Current cars:
FOTY 2008 winner!
Same issue?
I think I may be having the same problem. I was wondering if I should have power to the wire between the battery and the fusible links. I imagine I should and if not this wire may be bad or have a bad connection.
Let me explain what happened at the start of my problem. I tried to start the car at -44C. I had full power as normal until I turned the key, no I have nothing. Am I correct in assuming that the extra draw on such a cold start could have blown a connection that was corroded but working well enough when warm?
Oh I live in Saskatchewan.
^^yes"FLTG4LIFE" @FINALLEVEL , "PBH"
THis is what they look like.
Make sure you get the ones with the long slot between terminals.
There are one that have a short slot and don't fit as well.
ty 241. I did go to autozone and i did find em. I still had the old ones so figured since a few people were starting to have problems and that was the solution, i figured i would get me a couple and put them in and keep spares in glove compartment. I pm'd skeeter and he also told me which ones. ty guys, appreciate it. The brand name i got were bussman and pinks wer 30 amp and green 40 amp (main)
i get them free from work...i pull 10-20 a day. They're too expensive at autozone or orielly's---------------------------------------------------
I do what festivaWes does!
Every time I go to the JY I pick them up!
Some people don't want used fuse cartridges so I generally explain where to get them and what they look like.
I've never had an issue with the JY ones and have plenty of spares and have sent more than a few out to other members and have given them away at meets.'93 Blue 5spd 230K(down for clutch and overall maintanence)
x2 just make sure to get the ones with the deep notch. I had a bunch of spares with the shallow notch in my car and one day I blew the main.. I thought my spares were gonna save me.. no luck, at the time I didn't realize the ones with the shallow notch wouldn't work. Luckily I was in the auto-parts store parking lot!89SX funtop! Fully loaded!
RIP 90LX
stefan, I did the same thing!
If you break the plastic housing off the cartridges ceramic fuse holder carefully they will insert and work fine!
But the fuse is exposed to the elements and I will not be surprised when it goes.
The one is still working after 3-4 months!
Got the long notch replacement in the ash tray waiting for when it goes.'93 Blue 5spd 230K(down for clutch and overall maintanence)
