Hi Everyone,
This isn't really a repair question, but a general question about why something works as it does.
On the DeathEgg (88L+, Carb) Per the owners manual, I usually pump the gas pedal once and then it starts right up, if not on the first try, then quickly on the second.
However, These days when it's cold in the morning (anything under 50 it seems), once doesn't do it. Sometimes twice will do it, and just this morning I had to pump it 6-7 times (again, per the manual) and then it started. Once last week I had to hold the gas pedal down and crank it, the procedure you do when It's flooded. It took about 10 minutes to start. Once it's warm it starts quickly, all the time.
So, I guess I do need an answer as to why it's not starting, but also need an answer to what is happening when I pump the pedal so I may understand better why it's happening.
I know it sets the choke, right? So why would two pumps of the pedal work when one doesn't? Did it set the choke AGAIN? And for that matter, why 6-7 pumps like this morning? Did it set the choke 6-7 times?? Does pumping it actually squirt a little fuel into the engine?
Thanks!
Thanks!
