My Festiva has been giving me a problem that I have not been able to figure out. It is a
1990 L plus, Fule injected, 5 speed, only major mod are 14 " rims and tires that put the Speedo off about 3 miles per hour and a straight through exaust. The problem was first noticed last September while running the 4 lane at 65-70 miles an hour. The car started losing power and speed dropped to where I could not keep it going 55 miles an hour in 5th gear, droping it into 4th gear and punching the pedal to the floor, it can eventualy make it back up to 65 mph, but as soon as you put it back in 5th speed starts dropping off again. When this is happening the tempurature rises on my temp gage to about half way, when it is running normaly it never makes it to the second mark. The engine sounds like it is not running normaly, possibly a miss. Then it will disapear and run normally, the temp drops back to normal and till its next trip on the interstate ,it will run fine. Plugs ,wires,thermostat , o2 sensor and airfilter have been replaced. The problem does not occure while driving at normal speeds...just sustained speeds above 65.... anyone have a clue?
thanks in advance
thanks in advance
