auto belt relay
  • auto belt relay
    can some show me a pic of the automatic seatbelt relay cause my seatbelts wont work and i need that fixed
    anyone?:help:
      It's the box under the drivers seat.
        ^^Like he said, right under the drivers seat. Its about 6 inch's by 4 inch's. Festvamotorsport.com has new ones cheap.
        93 GL modyfied!!!
        :fish:
          How do you know its the seat belt relay causing them (both of them?) not to work?
            Originally posted by Pu241 View Post
            How do you know its the seat belt reply causing them (both of them?) not to work?
            cause if sometimes they will work they will go like half way... stop.. then go again after i hear the relay clicking
              It may not be the control box.
              On the rear interior panel....left and right...behind the front seats...is a liitle plug that can be removed to access the track motor for the seat belt. Not necessarily the motor but the cables go bad.
              Pop the plugs and insert a 5mm hex key and turn the motor to verify that the seat belt fully extends and retarcts. The cars were shipped from the factory with a 5mm hex key in the glove box. Also the owners manual has picts and directions to assist.
              Joe Lutz
              The SKATE ..... 1992L 5spd
