My one auto is very similar sounding to that... But mine will idle till I put it in gear and then it dies unless i give her some throttle....
PLEASE HELP!!!festiva starts but stalls!!!
Festiva VAF,Aspire MAF!!!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
VAF = Vane Air Flow. Flapper door type air flow meter
MAF = Mass Air Flow. Hot and cold resistor wire (Wheatstone bridge volotage divider) flow meter
MAP = Manifold Absolute Pressure. Small sensor (variable capacitor tied to a frequency generator or analog voltage generator) used to determine manifold vacuum relative to air pressure. Only used on Speed/Density type EFI systems (no air flow sensor)
OBDI started in 1986 to 1995
OBDII started in 1996 to currentJim DeAngelis
So can anyone scan the appropriate section out of a manual so carlosandpeppes can test his TPS?
I don't have access to a scanner myself yet but will like have one next week.'93 Blue 5spd 230K(down for clutch and overall maintanence)
carlosandpeppes
I appreciate you letting us know what the problem was.
Many times we never hear back after the problem is fixed!
Can you look over the VAF and determine what the problem was with it?
Do you need another VAF for your other festiva?'93 Blue 5spd 230K(down for clutch and overall maintanence)
Jim, you know too much!
(thats a good thing)
thanks for expaining the difference in sensors, i didn't know that.
ps. let me know when your stuff arrives.Last edited by ejp2fast; 01-22-2009, 02:31 PM.
-Aspire brake swap COMPLETE!
I didnt really check the faulty vaf, could it be the flapper was closed shut, causing the engine to gasp for air?Is the flap supposed to move freely or have a lil bit of friction?
I sure wouldnt mind getting another one to get my other one running again. I also need a spare distributor. Besides festivas and aspire models, can i use a distributor from a b6?
AFTER
