My new radiator came in! The only thing is, on the bottom, there's 2 brass (or metal most likely) tubes. I'm guessing these are for an auto trans? My car is a 5 speed. It didn't come with any caps to cap it off or anything. Can I get something like that at a parts store? Thanks!
Question about my new radiator
You should be able to get brass caps at any Lowe's or Home Depot to cap those off if they are not needed. I believe they are for the auto tranny.http://www.cardomain.com/id/hawkdoc60
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
yep, those fittings are for auto tranny... cap em off... auto radiator is an upgrade from the manual radiators as its dual core...
stay cool!
-Aspire brake swap COMPLETE!
I put a new dual-core (automatic) radiator in the 'Egg a few months ago; didn't even bother capping those lines. Maybe I should have but I do not see why. The only fit problem, if you can call it that, is that it is wider that my old very thin radiator, and so it was a tight fit getting it in the engine compartment.
Interesting side note: I initially hooked up the two fan leads backwards so the fan didn't run; even with the high heat in SoCal and no fan to help with cooling, it was just fine, and temp was normal. I love those dual-core radiators.
no fitment issues
you don't need to cap off those ports at the bottom. Nothing will leak out of them. They are the inlet and outlet to a separate tank/cooler inside the lower radiator tank. In an auto trans car, auto trans fluid would be circulated thru them to expell heat from the trans fluid into the coolant.Jim DeAngelis
and if you see coolent driping out of them, you know when to change the rad!!Trees aren't kind to me...
Wouldn't it be a good idea to cap the ATX ports just to prevent anything getting in their and prevent it from un-necessarily rusting out....what do caps cost...a couple $ each...whats a rad cost...+$100.Joe Lutz
The SKATE ..... 1992L 5spd
I ran a piece of fuel line to both on mine. They are just hooked together now.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
