Uh - Oh !!!
  • Uh - Oh !!!
    Just drove my '88 around the block. The motor was making a metal ringing sound. When I parked it, I noticed it was leaking oil! It's never leaked anything before. What's the bad news?
    Probably a head gasket?
    -Josh R
      oil filter loose??
        i'LL CHECK THE OL FILTER. wHAT WORRIES ME IS THE METAL RINGING NOISE BEFORE IT STARTED LEAKING. i WAS THINKING MAYBE RINGS?
          It almost sounds like you were about to throw a rod. Let us know where the oil was coming from and we might be able to help you narrow it down better.
          http://www.cardomain.com/id/hawkdoc60
          01 Chevy Impala 9C1 police package "Unnamed yet". 154K
          88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
          88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
          06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
            I crawled under it. It was dripping off the oil pan. Seemed like it might be coming from the front of the motor.
              With the oil coming from the front (front of engine, or car?), it could be the oil pan gasket or the front oil seal. The noise is what has me worried. If I was closer, I'd be happy to come and take a look. It could also be minor like valve ticking due to low oil.
                Last time I took it in for an oil change, they wouldn't do it. He said something about the motor making the ringing sound. That's all he said. It wasn't knocking, or overheating. Still has plenty of power (for a 1.3). Starts right up. I appreciate the offer to look at it. PA. is pretty far away.
                  Oh yeah, it's coming from the front of the motor.
                    I'm also getting a lot of blow by oil into the air breather.
                      The cars are known to blow the front crank seal. Hopefully your ringing is low on oil.
                      93 GL modyfied!!!
                      :fish:
                        I'll check it out in the morning. Thanks for the help! This site is awesome!!!
                          My Silver Bullet started blowing oil into the breather at about 250,000 miles. It still kept going for another 150,000. There was never any real noise, though. It is entirely possible that you are indeed dealing with low oil level causing valve noise. How many miles are on it?
                            don't let it run out of oil!! keep a quart or 2 with you at all times.
                            -Aspire brake swap COMPLETE!
                              I'd fix that pan gasket and front seal. Then just keep an eye on the dip and keep oil in the motor like eric said.
