After driving for about 20 mins yesterday, as I was getting out of my car I heard a hissing noise coming from the gas cap. Is there a vent to release pressure behind the cap or is it leaking? Normal or no?
Gas vapor leak?
Also check your cap. It is supposed to hold pressure, if its not then replace the cap. It's also the easiest and cheapest thing to start with"If you're not first you're last!" -Ricky Bobby
-91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
The little Festy that could...and did!
(Gone on to a new life)
-90 Ford Bronco II Eddie Bauer
i have vapors build inside the car, all hoses / lines seem fine and no cracks in canister. Is it possible my purge valve doenst work anymore and vapors are forced out hoses lines at connection points? somebody help me93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
If you hear vapor noise from the cap the cap sounds like its not sealin and the vacuum pressure is pulling from the tank end, try jump the solenoid open and see if you can hear it click. Then check the connectors etc."If you're not first you're last!" -Ricky Bobby
anyone can help?93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RJ
After Gas cap change, still have issues
So I changed the gas cap and that seemed to solve the problem, or rather the symptoms. Then the other day I was filling up and heard gas vapor rush out of the tank when I pulled the cap off. I think there is an issue at the evap cannister and the new cap is just sealing in the pressure better. So I'm going to look at the cannister this weekend, but am I able to simply vent the tank fumes to the atmosphere? What I was thinking of doing was capping the nipple on the evap cannister for the gas tank hose and letting the tank vent to the outside air. I know this is not emisison friendly, but other than that, are their any drawbacks to this setup?1993 Festiva GL
new fuel pump
97 B3 swapped in by Eurotiva
