Need tranny/shifter help please
  • Need tranny/shifter help please
    Mine has 264000. It's a 1990 L. I have a question. I recently (this week) lost 1,3,5 gears on my 5 spd. A friend of mine and myself found that the u-joint in the shifter linkage is worn out. It's next to the trans. Does anyone have a replacement part number for this? I'm having trouble locating one and I need my 'stiva to drive to work.
    Thanks
    Jerry
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
    My 93 lost it's transmission when it was new..like 20,000 miles...the linkage on top of the transmission supposedly had not been tightened after they adjusted the clutch at the dealer. Sounded like I had just gotten married and was dragging cans along the back of the car! I had NO gears! It had performed flawlessly and then BAM!
      Go to www.rockauto.com. I'm pretty sure that they had the shifter bushing that you are looking for. At the very least, it will show you a part number, that you can cross-reference at a local parts place.
      Good Luck!
      Scott
      Famous Last Words: "How hard can it be?"
        Even a used one from a JY or someones parts car would buy you time, maybe a lot of time!
          Haven't been able to find one in a junk yard(called around Friday). No one around here seems to have any cars left. The Rockauto link has seals but no shifter u-joint. I'll pull it out and check with the industrial bearings places next weekend.Thanks again for the help.
          Jerry
          Jerry
          Team Lightning
          93 L Lightning. BP
            It's embarassing but.... I looked again and it look like the diagram from Ford. NOT A U-JOINT. Still haven't found the bushing. Anyone have any ideas.
            With egg on the face.
            Thanks
            Jerry
            Jerry
            Team Lightning
            93 L Lightning. BP
              I made my shifter bushings out of door hinge pin bushings for a Chevrolet. I had to use a Dremel Tool to grind the inside diameter so the bolt would fit thru. Took about 10 min. to make them.
              1960 willys pickup
              1967 jeep cj5
              1988 festiva
              1989 festiva
              1990 festiva for parts
              1991 s-10
              "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
                you can get a bushing assortmant from autozone for van doors. There are some in there that fit pretty good. They are an easy fix for a while.
