update (with more clues!)
I went out today and took off the distributor cap, since I have read that sometimes oil gets in there and interrupts the electrical signal.
Sure enough, inside the distributor cap there is oil, along with oil on the outside of the dust cover. I removed the dust cover, and there is a fair amount of oily buildup in there.
I replaced the distributor cap last year, and do not recall seeing oil on the inside of the cap, so this seems to be a new development.
I have read on here that you can use either brake cleaner or carb cleaner to spray inside there, to clean all the oil out. Is this safe to do, and will it help?
Thanks again for all the help guys, esp you, Jim.
