Couple of Questions
  • Couple of Questions
    First, my Festiva is running great, but in 5th gear at 3k RPM's it feels like the car is going to come UNGLUED. It begins to shake and rattle down the road, and the rear hatch makes an interesting sound. Anyone ever had this happen? Second, can anyone tell me how fast 3k RPM's in 5th gear is? My speedo just went out, but my tach is fine. Thanks in advance.
    1990 Ford Festiva
    1993 Lexus SC400- 4.0L V8
    A little over 70 MPH. You need to check your wheels , and tires.
      That's around 70mph. Sounds like you need your wheels balanced, or possibly new tires.
      Jim DeAngelis
        Fresh, what is it with you and posting a minute before me?
        Jim DeAngelis
          Dont want to lose J.ess's favor .
            The wheels and tires seem to be fine. Good tread, rims are straight. Should I replace the bearings, or go for an alignment? 70MPH, not bad, I guess I should keep it under that anyways...
            1990 Ford Festiva
              Nice video Fresh! I was driving the turquoise car down the freeway once, going about 70 and sounded like the RPM's were going thru the roof!
              -Josh R
                Great video! Almost 75mph, I'm gonna get pulled over...haha thanks
                1990 Ford Festiva
                  Here is a better one
                    haha.
                    you two are silly.
                      Uh, when did you say you got your license?
                        Mine doesn't even make it to 70 unless I'm going slightly downhill. lol.
                        1989 Ford Festiva rollin on 13s
                        1991 Ford Festiva B6T in the works
                        1994 Mazda RX7/LS1 ( 438/490 ) Mustang Dyno "The Heart Breaker"
                        - 0 to 103 MPH in 660' / 136 MPH in 1320'
                        2001 F250 4" lift on 35s
                        2005 Subaru STi ( 471/448 )
                        - 0 to 92 MPH in 660' / 120 MPH in 1320'
                          I will be getting my license in April, I had my permit with me at the time I was driving on the freeway. So it's not like I was being illegal
                          -Josh R
                            Mine is doing the same thing. The noise from the hatch is really annoying. I run 70 basically the whole time I'm in the car b/c its highway all the way to work and back (last tank I got 41mpg, I figure thats good for running that speed all the time, ha). I'm about 90% sure that the shaking is coming from the struts/shocks being completely blown. I'll know for sure in a couple of weeks when I replace it all. I also had a shake in the front, so I moved the front tires to the back and all was smooth. I believe one of the front tires may be breaking loose from the inside b/c all the tires look lfine.
