While taking things apart to change the seals yesterday I was reminded that I get a bunch of oil in my intake pipes. So much, in fact, that here was some on the air filter
I'm NOT inclined to go to all the trouble of replacing the valve stem seals on an otherwise good engine, so I came up with a possible solution (kinda
). The lowest spot in the circuit is right where the first section of rubber pipe joins the VAF. So, I drilled a ~1/4 hole in the underside of the pipe there so the oil can drain out. But we don't want air leaking in there so I took some cotton clothes line rope, tied a knot near the end and poked it through the hole from the inside. I then tied another knot on the outside, snug against the pipe, and left a few inches hanging down. It's too soon to tell if it works, but the idea is that when the car is parked the oil will run down there, soak the rope and drip out.
