What is the proper cylinder compression ratings for the festiva? And what is the proper way to test it?
I disconnected the coil hooked up the compression tester and turned the engine over a few times on each cylinder leaving the other plugs in of course...
What I found was starting at the passenger side working to the right 35psi 135psi 90psi 80psi
Now I know that those readings pretty much mean a pooched engine but I just wanted to find out what the actual proper readings should be and if I was doing the compression test right....
