I've pm'd a couple members, but thought I'd throw this out to the rest of you for any and all help.
I have a '93 auto motor that a guy could not start. I pulled the coil wire out of the distributor, and HAVE spark coming out of the coil wire. I plugged it back in, removed the number 1 wire from the spark plug, I have NO spark. So, I figured the distributor had gone bad. I have a distributor that came off a motor that threw a rod out the side of the block. Now, I realize assuming is not good, but I assumed the distributor is good. I installed the "new" distributor and came up with the same results, no spark coming from the distributor. Now I can remove a known good distributor from a running car out in the back covered in snow, but was wondering if I am doing something wrong or if there is another component that I am not thinking of, that could be bad? Any help would be appreciated.
Thanks in advance,
Dan "Levitan"
Thanks in advance,
Dan "Levitan"
