I've been a member for over two years, but this is my first post. I've spent many hours reading mostly in the repair forum while trying to get my Festiva going. I have a 1990 FI manual with no rust at all. I passed by a used car lot one day and saw my Festiva. It was love at first sight. The car wouldn't start and the lot owner said that an employee let it "get hot." I went back that night and found that I could start it with starter fluid & also noted that i did not hear the fuel pump running. Pulled it away from the lot with little invested.
With the help of my Dad and my Boss, I have tinkered with the Festiva off and on over the past two years and have made the following repairs. New fuel pump and filter, remanufactured injectors, plugs and wires, timing and drive belts, remanufactured head (cam,valves,seals,etc.) Prior to installing the head, the car would start and run very rough. When reset, timing would jump 180 degrees causing me to opt for the new head based on the assumption that I had some type of valve issue.
Now it will not start. It hits and fires, but won't keep going. I have adequate pressure on the fuel rail and have checked the injectors electrical signals with borrowed noid lights. Cylinders 1 and 4 build slightly higher pressure that 2 and 3, but all appear adequate. There is plenty of fire.
Any ideas if my problem is electrical or mechanical? It sounds just like a car with a bad fuel pump, but the fuel is there. I LOVE this car, not running is not an option. Any ideas appreciated.
