I've got a weird problem with my windshield wipers. First thing in the morning (its been pretty cold outside), when I start my car and turn on the wipers, nothing happens. So I leave the wipers on and start driving anywhere from 5 minutes to 20 minutes and all of a sudden the wipers start working normally. I unplugged the connector at the switch and put some dielectric grease in there and reinstalled but it still does this. When the wipers first start working, they're really slow and then about 2 to 3 minutes later, they're working at normal speed. So, do you think it is a bad switch or a worn out wiper motor? My car has 184k miles on it and it looks like the original motor.
Is it the switch or the motor?
I would say it is motor related. However, I do not necessarily believe it is going bad. It may just need to be disassembled and lubed up real good and reassembled. I would try that and see if it works. If not, wiper motors are not uncommon on eBay.http://www.cardomain.com/id/hawkdoc60
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
the weather can affect them as well.Trees aren't kind to me...
I has the same situation a couple of years ago....about a mile from home I went to turn the wipers on and they did not respond. I found I had 12V at the connector...the ground wire was corroded. The ground connector is located on one of the lower wipper motor mounting bolts....I cleaned it up and re installed it with some copper based anti-sieze.Joe Lutz
The SKATE ..... 1992L 5spd
