i have a 90 festy and swapped over the aspire brakes all around. also swapped in an aspire booster and master cylinder (did not swap in the proportioning valve). and as an fyi, i am using a clear hose and a one-way bleeder valve so i can see if there is any air in the lines and make sure it doesnt go back into the caliper as a i bleed. in addition, im doing this w/ someone pumping while i bleed/open and close the bleeder valve on the caliper. all that to say, i dont see how any air could be getting back in while im doing it.
using the above method, i bled the brakes the first time and they were still spongy/soft. (cant remember if it was off or on the first time i did this). had to wait a few weeks until i had time to do it again and finally had some time over the weekend.
in case it matters, the car was off / not running. went around and did each corner a few times. still felt soft. went around a few more times and after a while the pedal finally started to harden up. thought the problem was fixed. put the car on the ground. started it up and the brake pedal went soft again!!! i have also noticed that the car kind of seems to want to die when i push in the pedal (would this point to a booster issue? but a bad booster wouldnt make the pedal soft would it? wouldnt that point to a bad m/c assuming there is NO air in the lines?).
i have no idea what the problem is and would love any advice you guys may have to offer. and im happy to try bleeding them again if anyone things im doing something wrong. ive worked on a lot of cars (including doing complete brake swaps just like this) and never had this much trouble w/ brakes.
thanks.
thanks.
