Horn Relay Location?
  • Horn Relay Location?
    i have been trying to find the horn relay under my dash to run a new wire out to the engine compartment for a while now, but to no avail. my horns were so quiet i decided to upgrade them to a louder model and when i got everything intalled i found out i had a break or short somewhere in the wiring cause they barely even worked at all then stopped working completely. when i push the buttons i can hear the relay clicking but cannot get my big self far enough under the dash to find it to run a new wire out. the horn wire in the engine compartment is green with an orange stripe, but not inside. inside its the wire for the turn signals (as i found out rather embarrassingly). i have a haynes manual but it doesnt show or say where it is, just says what a relay is.
    can anyone tell me where to find it? id really like to be able to have a horn again since it gets a lil hairy not having a horn with the idiots on the road where i live (they drive worse than me lol).
    check out this link:
    -Aspire brake swap COMPLETE!
