Exhaust gasket question.
  • Exhaust gasket question.
    Quick question... can a header be installed using the stock exhaust manifold gasket? Can the gasket be reused?
    Thanks
    Ian
    I have reused my exhaust gasket (stock components) and had to torque the three 14mm bolts a little more than I did when it was a new gasket, and it doesn't leak...
    -Aspire brake swap COMPLETE!
      im assuming you have the 1.3 where did you find a header for it?
      1991 blue L, 5 speed.
      1988 red L-plus-all stock.
        According to his sig he has a B6.
        93 GL modyfied!!!
        :fish:
