Relay noise
  • Relay noise
    I have a relay (near the battery, under the radiator resevoir) that is constantly making even with the key turned off. I believe this is an ignition relay. What would make it keep trying to make and is the relay bad or is there something else wrong. 91 Festiva with a manual trans.
    is it ticking like a solenoid on and off, and what kind of noise? Maybe it is fusible link related..
    -Aspire brake swap COMPLETE!
      It is ticking like a solenoid, but it most definantly the relay contacts because when I finally dug it out from behind the wire loom I could feel it also.
        sounds like a bad relay then... i think its the headlight relay.. but don't know for sure.
          I got to thinking that it might be the headlight relay, but why would this keep the car from starting?
            oh, if the car isn't starting, its the starter solenoid likely... what i'd do is tap the starter solenoid with a small hammer or something of the like and then try it again... sometimes that solenoid sticks...
              The main relay and headlight relay are behind the left headlight. Main relay black wire is ground, blk/wht is 12v in from the eng fuse under steering wheel, wht/blu is 12v in from the egi fuselink, and yel/black is power out to everything (fuel pump relay, injectors, applicable sensors, etc...). Assuming the egi fuselink is good, you can use a jumper wire between the wht/blu wire and yel/blk wire to see if the car will run. If it does, get a new main relay. Also, with the key on, engine off, check for battery voltage at the blue or black/white wire going to the coil. The coil gets its power straight from the ignition switch. Sorry for the novel, hope this helps.
                I will certainly give it the ol college try.
